Monitor dla programisty - Spis modeli EIZO i NEC
Tred
14 lipca 2018, 17:07 - sob
Witam jako nowy użytkownik forum.
Potrzebuję zestaw 2 monitorów. 80% czasu programuję w c#, c++, 20% czasu czytam dokumentacje + fora internetowe. Poszukuję monitorów z naciskiem na ochronę wzroku i redukcję zmęczenia.
Szukając dobrych dla programistów propozycji zrobiłem spis za maximum określając NEC EA275UHD-CT (jeśli coś pominąłem proszę o poprawienie)
24" [16x10] [1920x1200] NEC EA244WMi [IPS] [sRGB] [W-LED] [PWM 280Hz] [✔︎] 1308
24" [16x10] [1920x1200] NEC EA245WMi [IPS] [sRGB] [W-LED] [PWM 8KHz] [✔︎] 1520
24" [16x10] [1920x1200] NEC MultiSync EA245WMi-2 [IPS] [sRGB] 1621
24" [16x10] [1920x1200] EIZO EV2455 [IPS] [sRGB] [W-LED] [PWM+DC 200Hz] [✔︎] 1809
24" [16x10] [1920x1200] NEC EA244WMi-CT [IPS] [sRGB] [W-LED] [PWM 280Hz] [✔︎] 1870
24" [16x10] [1920x1200] NEC EA245WMi-CT [IPS] [sRGB] [W-LED] [PWM 8KHz] [✔︎][☹] 1899
24" [16x10] [1920x1200] NEC EA245WMi-2-CT [IPS] [sRGB] [W-LED] [PWM 8KHz] [✔︎] 1989
24" [16x10] [1920x1200] EIZO EV2456 [IPS] [sRGB] [W-LED] [PWM+DC 200Hz] [✔︎] 2319
24" [16x10] [1920x1200] EIZO EV2430 [IPS] [sRGB] ?????
27" [1x1] [1920x1920] EIZO EV2730Q [IPS] [sRGB] [W-LED] [PWM+DC] [✔︎][♛] 4179
27" [16x9] [1920x1080] NEC MultiSync EA271F-CT ColorTuned [IPS] [sRGB] ?????
27" [16x9] [1920x1080] Monitor NEC MultiSync EA271F ?????
27" [16x9] [1920x1080] Monitor NEC MultiSync E271N [AH-IPS] [sRGB] ?????
27" [16x9] [1920x1080] NEC MultiSync E271N-CP ColorPreset [AH-IPS] [sRGB] ?????
27" [16x9] [1920x1080] Monitor NEC MultiSync EA273WMi [IPS] [sRGB] 1809
27" [16x9] [2560x1440] NEC EA275WMi [IPS] [sRGB] [W-LED] [PWM 8KHz] [✔︎][♛] 2671
27" [16x9] [2560x1440] EIZO EV2736W [IPS] [sRGB] [W-LED] [PWM 200Hz] [✆] 3095
27" [16x9] [2560x1440] NEC EA275WMi-CT [IPS] [sRGB] [W-LED] [PWM 8KHz] [✔︎][♛] 3151
27" [16x9] [3840x2160] NEC EA275UHD [AH-IPS] [sRGB] [W-LED] [PWM] [✔︎][♛] 3419
27" [16x9] [2560x1440] EIZO EV2750 [IPS] [sRGB] [W-LED] [PWM+DC] [✔︎] 3548
27" [16x9] [2560x1440] EIZO EV2780 [IPS] [sRGB] [W-LED] [PWM+DC] [✔︎] 4265
27" [16x9] [3840x2160] NEC EA275UHD-CT [AH-IPS] [sRGB] [W-LED] [PWM] [✔︎][♛] 4304
27" [16x9] [2560x1440] EIZO FS2735 [IPS] [sRGB] [W-LED] [PWM+DC] [✔︎] 4599
24" [16x9] [3840x2160] Dell P2415Q 1600
27" [16x9] [3840x2160] Dell U2718Q 2200
1. Czy jest sens kupować 27 cali 16:9 kiedy jest tak mała różnica w wysokości co do 24 cali 16:10 = 0,52cm ?
http://www.displaywars.com/24-centimetr ... metre-16x9
2. Zanim trafiłem na forum zastanawiałem się nad DELL-em przy moich wymaganiach może warto się zastanowić, jakość odwzorowania kolorów przecież nie jest mi potrzebna, a rozdzielczość [3840x2160] pożądana mimo problemów z podświetleniem, może porównując je do najniższej pułki NEC i EIZO pod kątem ceny zestaw nie był by, aż tak zły jako najskromniejsza para 27"?
27" [16x9] [3840x2160] Dell U2718Q 2200x2=4400
24" [16x9] [3840x2160] Dell P2415Q 1600x2=3200
hmm chciałem usunąć, ale zostawię i podlinkuję
viewtopic.php?f=5&t=3557&hilit=U2718Q%2C&start=60
czytując forum prawie tydzień dalej znajduję tyle sprzecznych informacji, że już nie wiem czym się sugerować
04 lutego 2018, 15:20 - ndz
Przepraszam, jeśli Pana uraziłem. Wypowiadam się zgodnie ze swoją wiedzą i doświadczeniem, wyłącznie w interesie wątkotwórcy. Niestety nie jest możliwe wypowiadanie się w interesie każdej strony.
Liniowość w arkuszu kalkulacyjnym nie ma najmniejszego wpływu na wyświetlanie czarnych literek i białego tła. Można ją w razie potrzeby poprawić do poziomu referencyjnego za 150zł, choć uważam to tutaj za zwykłą rozrzutność. Natomiast nie wiem za bardzo jak nazwać w tym przypadku dokładanie kolejnych kilku stówek.
Oczywiście, jak już również wspominałem, a Tom01 potwierdza, warto ponownie rozważyć DELL serii U.
Tak, czy inaczej sądzę, że zakładający wątek dowiedział tu się kilku rzeczy, które ułatwią mu optymalny wybór, a to dlatego, że wypowiadane są z różnego punktu widzenia.
3. Czy wybrać wersję z ColorTuned uwzględniając przeznaczenie do programowanie na czarnym tle?
4. Jakie dwa modele zebrać w zestaw, aby zadbać o wzrok nie przepłacając niepotrzebnie za jakość, której nie wykorzystam? Szukam dwóch zestawów. Jeden droższy drugi tańszy dla polepszenia pracy pracownikom (obecnie używają 2x po 22cale). Proszę o propozycje jednocześnie dla zainteresowanych tematem
03 września 2017, 21:25 - ndz
Wyobraź sobie, że używanie komputera to wbijanie gwoździa w kolano. Boli, prawda?
No więc Ty, ponieważ boli jak wbijasz gwóźdź, chcesz kupić nowy, niklowany, z pozłacanym łebkiem ... gwóźdź. No i może niklowany gwóźdź będzie lepszy od stalowego, nieco już podrdzewiałego, ale to nadal gwóźdź.
Po całym dniu pracy przy komputerze trzeba po prostu dać oczom (dupie, plecom i głowie) odpocząć, a nie dożynać je dalej do wieczora nowym monitorem - niklowanym gwoździem.
Jeśli jednak koniecznie chcesz, wbrew wszelkim zasadom zdrowego rozsądku, koniecznie używać dalej monitora w domu skup się na właściwym wyregulowaniu monitora i oświetleniu stanowiska, tak jak wytłumaczył to wyżej Tom01. To będzie miało realny wpływ na poprawę komfortu użytkowania. Natomiast kupno nowego monitora, nieco tylko lepszego niż poprzedni, będzie miało wpływ pomijalnie mały, a najprawdopodobniej różnicy nie będzie żadnej.
Można też, jak sugeruje Tom01, kupić bardzo dobry monitor z bardzo wysoką rozdzielczością. Z całą pewnością wywoła on efekt łał. Jednak jeśli będzie on niewłaściwie wyregulowany, otoczenie będzie za ciemne, będziesz się na niego gapił 16stą godzinę, to oczy i tak będą boleć, choćby monitor kosztował 50000zł. Po prostu człowiek ma tendencję do przyjmowania nienaturalnej pozycji podczas patrzenia w monitor, ma tendencję do zapominania o mruganiu, nie korzysta z akomodacji wzroku czyli zmiany ogniskowej itp. itd. To wszystko ma szkodliwy wpływ na wzrok.
15 marca 2018, 21:25 - czw
Dobry monitor, źle wyregulowany, w ciemnym otoczeniu, będzie męczył.
Przeciętny monitor, dobrze wyregulowany, w jasnym otoczeniu, nie będzie męczył.
Ode mnie propozycje amatorskie:
24"
EIZO EV2430 [IPS] ????
vs
NEC EA245WMi-2 [1920x1200] 1621x2=3242 Sugerowany tańszy zestaw
vs
EIZO EV2455 [1920x1200] 1809x2=3618 (traci sens w porównaniu z EA245WMi-2-CT?)
vs
NEC EA245WMi-2-CT [1920x1200] 1989x2=3858 Sugerowany droższy zestaw
27" Ekonomiczny
nowe modele NEC E_271_??? [1920x1080] Jakie są prognozowane ceny sprzedaży?
27" Optymalny
NEC EA275WMi [2560x1440] 2671x2=5342 Sugerowany tańszy zestaw
vs
NEC EA275WMi-CT [2560x1440] 3151x2=6302
27" Idealny
EIZO EV2750 [2560x1440] 3548x2=7096 (traci sens w porównaniu z NEC EA275UHD?)
vs
NEC EA275UHD [3840x2160] 3419x2=6838 Sugerowany droższy zestaw
vs
NEC EA275UHD-CT [3840x2160] 4304x2=8608
Ceny zaczerpnięte ze sklepu monitory.mastiff.pl
Re: Monitor dla programisty - Spis modeli EIZO i NEC
14 lipca 2018, 18:07 - sob
Podszedł Pan do tematu metodycznie i zebrał wszystkie niezbędne informacje. W zasadzie, żadna pomoc nie jest potrzebna. Wybrane monitory są dobrymi propozycjami w swoich klasach. Oczywiście czym droższe tym lepsze, szczególnie w kontekście serii ColorTuned od NEC. 27" z rozdzielczością UHD da bajeczną ostrość tekstu, co jest niebagatelne przy prezentowanych zastosowaniach, ale i odmiany o "zwykłej" rozdzielczości 2560x1440, są bardzo dobre. Niżej nie ma co. Piksele się robią wielkości łebków od zapałek, ostrość spada na pysk. Co do wielkości, proponuję nie schodzić poniżej 27".
Tred
14 lipca 2018, 18:45 - sob
Opierając się na Pana opinii ostrość jako parametr pożądany zachęcam omijać monitory podane poniżej. Zastanawiałem się nad nimi w kontekście ceny w porównaniu z 24" [16x10] [1920x1200] NEC EA245WMi-2 jednak nie liczę, że poniższe znaki zapytania zamienią się w ceny niższe niż 1600zł, bo tylko w tym wariancie były by one godne przemyślenia. Zna Pan już ceny sprzedaży tych monitorów?
14 lipca 2018, 18:50 - sob
27" to spory ekran. Rozdzielczość powinna być tak dobrana, aby piksele były możliwie niewidoczne gołym okiem. Oczywiście w większości monitorów piksele są widoczne, jednak istnieją pewne zakresy rozmiarów, kiedy da się na nie patrzeć bez męczenia oczu i te się w nich nie mieszczą. Pracowałem przez krotki czas na 26" o rozdzielczości 1920x1200 i wyznam, że to był koszmar. Tekst dramatycznie nieostry, oczy mimo to próbują dokonać niemożliwego akomodacją. Szczerze odradzam. Ceny wspomnianych modeli będą niskie, niewiele powyżej poziomu wersji 24-calowych.
14 lipca 2018, 23:03 - sob
Monitor dla programisty? - jakieś 27" 3840x2160 powinno oblecieć . Po to wysoka rozdzielczość, by czcionki były gładkie i ostre ... i wygodnie duże (dzięki systemowemu skalowaniu takie będą).
Liczba postów: 70065
